Roulette panier inferieur
Reference ADEPEM : 068761
Joint bas de porte 1527401002
Reference ADEPEM : 041333
Reference ADEPEM : 068760
Reference ADEPEM : 047417
Reference ADEPEM : 057375
Pompe de vidange bpx2-14l
Reference ADEPEM : 187912
Joint tour de porte l=174cm
Reference ADEPEM : 114948
Electrovanne 1 voie 55x8399
Reference ADEPEM : 030809
Reference ADEPEM : 038863
Panier a couverts 1525593008
Reference ADEPEM : 074931
Bouchon bac a sel as0007123
Reference ADEPEM : 100221
Serrure + poignee blanche
Type: Securites et verrousFar, Aya, Continental edison
Reference ADEPEM : 138421
Reference ADEPEM : 056074
Resistance 1800w , 49025127
Reference ADEPEM : 157271
Support glissiere + roulettes
Reference ADEPEM : 159878
Bras de lavage superieur
Type: Bras de lavageCalifornia, Continental edison, Aya
Reference ADEPEM : 083117
Boitier
Reference ADEPEM : 073876
Kit turbine+joint
Reference ADEPEM : 034372
Pompe de cyclage
Type: PompesCurtiss, Proline, Urania
Reference ADEPEM : 135094
Roulette panier
Type: Supports et fixationsCurtiss, Far, Baumatic
Reference ADEPEM : 147480
Electrovanne pneumatique
Type: ElectrovannesFaure, Zanussi, Arthur martin
Reference ADEPEM : 036554
Type: Bras de lavageZanussi, Faure, Arthur martin
Reference ADEPEM : 045843
Ressort poignee
Type: Amortisseurs et ressortsFaure, Zanussi, Arthur martin
Reference ADEPEM : 061734
Type: Distributeurs lessiveAriston, Indesit, Curtiss
Reference ADEPEM : 058434
Bouton marche - arret
Type: BoutonsCurtiss, Proline, Urania
Reference ADEPEM : 140087
Conduit bras superieur
Type: Tubes et conduitsFaure, Zanussi, Arthur martin
Reference ADEPEM : 042097
Gicleur central bras inferieur
Reference ADEPEM : 042255
Interrupteur marche/arret 4 cosses
Type: Interrupteurs et switchFar, Aya, Curtiss
Reference ADEPEM : 152462
Joint de conduit 152311901/2
Reference ADEPEM : 049027
Panier superieur
Type: Bacs et paniersProline, Aya, Continental edison
Reference ADEPEM : 122291
Pompe de vidange m239
Reference ADEPEM : 134700
Sonde temperature
Type: Capteurs et sondesProline, Oceanic, Curtiss
Reference ADEPEM : 112103
Crochet de porte
Type: Crochets et leviersCandy, Far, Aya
Reference ADEPEM : 159070
Durite de résistance 34421197
Type: Tuyaux et duritesThomson, Proline, Urania
Reference ADEPEM : 196008
Filtre tamis seche-linge
Type: FiltresIndesit, Vedette, Ariston
Reference ADEPEM : 059264
Joint alimentation bras superieur
Type: JointsProline, Curtiss, King d'home
Reference ADEPEM : 150321
Joint de fond de cuve
Type: JointsProline, Curtiss, Selecline
Reference ADEPEM : 178372
Pressostat 140/120
Type: PressostatsProline, Curtiss, Selecline
Reference ADEPEM : 131050
Switch de flotteur
Type: Interrupteurs et switchBrandt, Whirlpool, Fagor
Reference ADEPEM : 161044
Turbine pompe de cyclage
Type: Ventilateurs et helicesProline, Thomson, Valberg
Reference ADEPEM : 191910
Reference ADEPEM : 144222
Adoucisseur complet
Type: AdoucisseurFaure, Zanussi, Arthur martin
Reference ADEPEM : 045559
Anneau clip bouton programmateur
Type: DiversFaure, Electrolux, Zanussi
Reference ADEPEM : 082889
Arret de panier
Reference ADEPEM : 054453
Electrovanne (iwms2)
Type: ElectrovannesZanussi, Faure, Arthur martin
Reference ADEPEM : 061730
Type: ElectrovannesUrania, Friac
Reference ADEPEM : 071966
Filtre lave vaisselle (petit)
Type: FiltresZanussi, Faure, Arthur martin
Reference ADEPEM : 041397
Gicleur bras lavage inferieur
Type: Bras de lavageZanussi, Electrolux, Curtiss
Reference ADEPEM : 112825
Glissiere de panier superieur
Type: DiversArthur martin, Zanussi, Faure
Reference ADEPEM : 065334
Grille sortie buee
Type: GrillesZanussi, Faure, Arthur martin
Reference ADEPEM : 053768
Joint bas de porte en mousse
Type: JointsUrania
Reference ADEPEM : 152494
Joint d'adoucisseur
Type: JointsArthur martin, Faure, A.e.g
Reference ADEPEM : 063919
Joint de collecteur
Type: JointsA.e.g, Arthur martin, Zanussi
Reference ADEPEM : 108175
Plinthe inferieure
Reference ADEPEM : 080864
Pompe de vidange 290936
Reference ADEPEM : 069097
Pompe de vidange 53152
Type: PompesLaco, Markling, Unic line
Reference ADEPEM : 046024
Programmateur 514545
Type: Minuteurs et programmateursZanussi, Electrolux, Far
Reference ADEPEM : 057573
Thermoplongeur 2100w
Type: ResistancesZanussi, Faure, Electrolux
Reference ADEPEM : 017690
Thermostat 75°nc
Type: ThermostatsZanussi, Faure, Arthur martin
Reference ADEPEM : 042647
Tube alimentation
Type: Tubes et conduitsProline, Glem, Curtiss
Reference ADEPEM : 165201
Tuyau vidange 2m droit
Type: Tuyaux et duritesBosch, Siemens, Faure
Reference ADEPEM : 033683
Panier inferieur 672000803080
Reference ADEPEM : 131514
Pompe de vidange b30-6a
Reference ADEPEM : 106970
Joint ecrou bac a sel
Type: JointsCandy, Proline, Hoover
Reference ADEPEM : 162181
Panier inferieur
Type: Bacs et paniersContinental edison, Proline, Far
Reference ADEPEM : 136060
