Reference ADEPEM : 071219
Ampoule 15w e14 300°
Reference ADEPEM : 023507
Ampoule four 25w e14 300°
Reference ADEPEM : 023508
Roulette panier inferieur
Reference ADEPEM : 068761
Reference ADEPEM : 076419
Joint bas de porte 1527401002
Reference ADEPEM : 041333
Guide panier as0000006
Type: Bacs et paniersA.e.g, Electrolux, Fagor
Reference ADEPEM : 065706
Reference ADEPEM : 013193
Element chauffant 2000w 4055373700
Type: ResistancesA.e.g, Electrolux, Ikea
Reference ADEPEM : 168808
Reference ADEPEM : 059802
Pressostat analogique, 3792216040
Reference ADEPEM : 088228
Reference ADEPEM : 068760
Tuyau vidange coude 2m
Reference ADEPEM : 046715
Reference ADEPEM : 057375
Reference ADEPEM : 036022
Pressostat 140000554083
Reference ADEPEM : 156588
Reference ADEPEM : 041332
Pompe de vidange bpx2-14l
Reference ADEPEM : 187912
Reference ADEPEM : 102128
Type: Roues et roulettesA.e.g, Arthur martin, Faure
Reference ADEPEM : 036898
Module de puissance 8077075052
Reference ADEPEM : 141707
Pompe de vidange, 140000604011
Type: PompesA.e.g, Electrolux, Ikea
Reference ADEPEM : 157104
Type: Roues et roulettesArthur martin, A.e.g, Faure
Reference ADEPEM : 036184
Pompe de vidange bpx2-28l 140000443022
Type: PompesA.e.g, Electrolux, Progress
Reference ADEPEM : 115274
Sonde de temperature, 140000401061
Type: Capteurs et sondesElectrolux, A.e.g, Ikea
Reference ADEPEM : 177729
Boite produit 4071358131
Type: Distributeurs lessiveA.e.g, Arthur martin, Electrolux
Reference ADEPEM : 021974
Panier a couverts 1118401700
Type: Bacs et paniersA.e.g, Arthur martin, Electrolux
Reference ADEPEM : 042528
Reference ADEPEM : 034485
Module de commande*
Type: ModulesElectrolux, Faure, Arthur martin
Reference ADEPEM : 137075
Ecrou du repartiteur
Reference ADEPEM : 120155
Relais de chauffage 50296242006
Type: Relais et klixonsMiele, Frigeavia, A.e.g
Reference ADEPEM : 022907
Reference ADEPEM : 060855
Electrovanne 1 voie 1170958209
Type: ElectrovannesArthur martin, Electrolux, Faure
Reference ADEPEM : 065589
Sonde temperature 1113368003
Type: Capteurs et sondesA.e.g, Electrolux, Arthur martin
Reference ADEPEM : 066105
Bague de serrage 1250091004
Reference ADEPEM : 005244
Reference ADEPEM : 120158
Tuyau vidange 1,50m coude
Reference ADEPEM : 017906
Module de commande*
Type: ModulesFaure, Progress, Zanussi
Reference ADEPEM : 163971
Panier a couverts 1525593008
Reference ADEPEM : 074931
Panier inferieur 140133729099
Type: Bacs et paniersElectrolux, Faure, Zanussi
Reference ADEPEM : 125269
Type: Tubes et conduitsArthur martin, Faure, Electrolux
Reference ADEPEM : 091441
Fixation bras superieur 8070358018
Type: Supports et fixationsA.e.g, Electrolux, Ikea
Reference ADEPEM : 166351
Panier a couverts gris
Type: Bacs et paniersArthur martin, Zanussi, Electrolux
Reference ADEPEM : 068517
Pressostat 65/45 152818902/8
Reference ADEPEM : 070343
Joint alimentation de bras 11720410/4
Reference ADEPEM : 034269
Joint bas de porte l=400 152740110/1
Reference ADEPEM : 072304
Reference ADEPEM : 075295
Roulette de panier dx (droite)
Type: Roues et roulettesZanussi, Arthur martin, Electrolux
Reference ADEPEM : 063070
Roulette panier 50269748005
Type: Roues et roulettesFaure, Arthur martin, Zanussi
Reference ADEPEM : 017699
Tuyau aquastop 1,80 metres
Type: Tuyaux et duritesA.e.g, Arthur martin, Faure
Reference ADEPEM : 066119
Reference ADEPEM : 071320
Durite de resistance
Reference ADEPEM : 089887
Reference ADEPEM : 056074
Module electronique edw150*
Reference ADEPEM : 128574
Resistance 1800w , 49025127
Reference ADEPEM : 157271
Demi bague fixation bras
Type: DiversA.e.g, Arthur martin, Faure
Reference ADEPEM : 036527
Interrupteur marche / arret
Reference ADEPEM : 053073
Pressostat analogique 1174745107
Type: PressostatsA.e.g, Electrolux, Progress
Reference ADEPEM : 154698
Serrure loquet 4055283925
Reference ADEPEM : 068949
Bras de lavage inferieur
Type: Bras de lavageA.e.g, Arthur martin, Electrolux
Reference ADEPEM : 073660
Manche plastique
Reference ADEPEM : 084148
Module de puissance*
Type: ModulesA.e.g, Electrolux, Ikea
Reference ADEPEM : 166085
Module electronique 140101108110*
Type: ModulesA.e.g
Reference ADEPEM : 300394
Pompe de vidange 58967
Type: PompesA.e.g, Arthur martin, Faure
Reference ADEPEM : 063354
Roulette double
Type: Roues et roulettesFaure, Zanussi, Arthur martin
Reference ADEPEM : 061710
Support verres 1171817107
Reference ADEPEM : 178571
Tube alimentation bras superieur
Type: Tubes et conduitsA.e.g, Arthur martin, Faure
Reference ADEPEM : 046462
Adoucisseur
Type: AdoucisseurElectrolux, A.e.g
Reference ADEPEM : 087104
Bandeau de commande 14006025405/3
Type: Bandeaux de commandeA.e.g, Electrolux
Reference ADEPEM : 202883
Boitier
Reference ADEPEM : 073876
Reference ADEPEM : 095475
Bras de lavage supérieur 1174076024
Type: Bras de lavageA.e.g, Electrolux, Rex
Reference ADEPEM : 210593
Bras superieur
Reference ADEPEM : 021939
Durite coude
Type: Tuyaux et duritesArthur martin, A.e.g, Electrolux
Reference ADEPEM : 092627
Element de pulverisation inferieur
Type: Bras de lavageA.e.g, Electrolux, Zanussi
Reference ADEPEM : 197555
Inverseur de rotation de bras
Type: Interrupteurs et switchElectrolux, A.e.g
Reference ADEPEM : 158246
Reference ADEPEM : 049750
Joint de cuvette 5065923100/0
Reference ADEPEM : 058594
Joint de resistance
Reference ADEPEM : 138759
Joint filtre (grand)
Type: JointsZanussi, Arthur martin, Faure
Reference ADEPEM : 037606
Joint torique de cuve
Reference ADEPEM : 130449
Kit turbine+joint
Reference ADEPEM : 034372
Microswitch 2 cosses depart/securite
Reference ADEPEM : 013225
Module d'affichage edw1510
Type: ModulesElectrolux, A.e.g, Progress
Reference ADEPEM : 144465
Module de commande*
Type: ModulesA.e.g
Reference ADEPEM : 180836
Module de commande edw1100* 1113310526
Reference ADEPEM : 124098
Pompe cyclage
Type: PompesArthur martin, A.e.g, Electrolux
Reference ADEPEM : 033590
Pompe cyclage+turbine
Type: PompesArthur martin, Faure, Zanussi
Reference ADEPEM : 017707
Type: PompesFaure, Arthur martin, Zanussi
Reference ADEPEM : 037642
Type: PressostatsFaure, Zanussi, Arthur martin
Reference ADEPEM : 039332
Repartiteur d'eau 111813950/8
Type: RepartiteurA.e.g, Arthur martin, Faure
Reference ADEPEM : 066901
Ressort de porte
Type: Amortisseurs et ressortsA.e.g, Arthur martin, Faure
Reference ADEPEM : 090990
Roulette superieure
Type: Roues et roulettesA.e.g, Arthur martin, Electrolux
Reference ADEPEM : 072148
Support roulettes reglable droit
Type: Supports et fixationsElectrolux, Arthur martin, A.e.g
Reference ADEPEM : 103767
Support superieur bras cyclage
Type: Supports et fixationsA.e.g, Arthur martin, Faure
Reference ADEPEM : 055843
Switch 2 cosses securite porte
Type: Interrupteurs et switchArthur martin, Electrolux, Indesit
Reference ADEPEM : 004033
Trappe produit de rinçage
Reference ADEPEM : 182165
Traverse avant
Reference ADEPEM : 091622
Reference ADEPEM : 089895
Voyant ouverture de porte
Type: Lampes et ampoulesA.e.g, Arthur martin
Reference ADEPEM : 096370
Bouchon de rincage 4006045613
Type: BouchonsA.e.g, Arthur martin, Electrolux
Reference ADEPEM : 022030
Module de puissance 140059122220*
Reference ADEPEM : 212314
Boite produits 812890061
Reference ADEPEM : 040328
