Reference ADEPEM : 008807
Courroie 1930h6 = 6phe1930
Reference ADEPEM : 028368
Plateau tournant, d=271, 480120101083
Type: Plats et plateauxWhirlpool, Bauknecht, A.e.g
Reference ADEPEM : 010180
Palier gauche d=20mm 4071306494
Type: Roulements et paliersArthur martin, A.e.g, Faure
Reference ADEPEM : 036546
Palier droit d=20mm 4071306502
Reference ADEPEM : 037280
Roulement 6307z, 35x80x21mm
Reference ADEPEM : 050039
Pompe de vidange, c00044998, c00855480
Type: PompesHaier, Indesit, Ariston
Reference ADEPEM : 011982
Plateau tournant d=270
Type: Plats et plateauxBluesky, Galanz, Far
Reference ADEPEM : 046611
Courroie 1810j3 481935818131
Reference ADEPEM : 040007
Amortisseur 80n 379430301/0
Type: Amortisseurs et ressortsFaure, Electrolux, Zanussi
Reference ADEPEM : 045914
Courroie 1280j6 = 1282j6
Type: CourroiesArthur martin, Faure, Zanussi
Reference ADEPEM : 017801
Securite de porte, zv-446l10, as0033141
Type: Securites et verrousVedette, Proline, Continental edison
Reference ADEPEM : 172410
Resistance 2500w 32x4829
Reference ADEPEM : 030791
Reference ADEPEM : 038863
Soufflet de hublot as0040064
Type: JointsBrandt, Thomson, Vedette
Reference ADEPEM : 211161
Reference ADEPEM : 029939
Thermostat 147°na
Reference ADEPEM : 030939
Bague de fixation tuyau
Type: Tuyaux et duritesZanussi, Faure, Arthur martin
Reference ADEPEM : 099482
Cerclage hublot interieur
Type: HublotsFaure, Zanussi, Arthur martin
Reference ADEPEM : 010457
Fixation manchette inferieure
Type: Supports et fixationsFaure, Arthur martin, Zanussi
Reference ADEPEM : 040683
Pompe de vidange as0042300
Reference ADEPEM : 205656
Joint de thermostat
Type: JointsFaure, Arthur martin, Curtiss
Reference ADEPEM : 017441
Resistance 1950w 124032547/0
Reference ADEPEM : 005053
Joint de palier 22x40x8/11,5
Type: JointsArthur martin, Zanussi, Faure
Reference ADEPEM : 034434
Joint thermostat 481932568005
Type: JointsLaden, Curtiss, Whirlpool
Reference ADEPEM : 014224
Condensateur 8µf 450v
Reference ADEPEM : 113548
Crochet de porte lave linge
Type: Crochets et leviersArthur martin, Faure, Electrolux
Reference ADEPEM : 005579
Joint de cuve 124015903/6
Reference ADEPEM : 036198
Pompe de vidange as0033222
Type: PompesBrandt, Vedette, Urania
Reference ADEPEM : 163921
Pompe de vidange px-2-35 35w
Type: PompesHaier, Proline, Curtiss
Reference ADEPEM : 187937
Durite alimentation eau 3248413928
Type: Tuyaux et duritesFaure, Zanussi, Electrolux
Reference ADEPEM : 083201
Interrupteur 2 cosses noir marche-arret
Type: Interrupteurs et switchCurtiss, Far, Horn
Reference ADEPEM : 105822
Joint de palier
Reference ADEPEM : 040521
Joint de palier 30x52x10
Type: JointsFaure, Arthur martin, Zanussi
Reference ADEPEM : 030308
Joint de roulement
Type: JointsUrania
Reference ADEPEM : 207057
Poignee hublot blanche
Type: PoigneesFaure, New pol, Curtiss
Reference ADEPEM : 018958
Type: Securites et verrousCurtiss, Far, Horn
Reference ADEPEM : 051192
Type: JointsZanussi, Faure, Arthur martin
Reference ADEPEM : 005387
Soufflet de hublot 126041620/9
Type: JointsFaure, Zanussi, Arthur martin
Reference ADEPEM : 005388
Thermostat 60°nc rearmable
Type: ThermostatsFar, Bluesky, Franger
Reference ADEPEM : 072004
Touche blanche
Type: BoutonsFar, Faure, Arthur martin
Reference ADEPEM : 093274
Amortisseur
Type: Amortisseurs et ressortsBeko, Urania
Reference ADEPEM : 097076
Boite lessive
Type: Distributeurs lessiveArthur martin, Curtiss, Far
Reference ADEPEM : 053563
Bornier
Type: ConnectiquesZanussi, Faure, Arthur martin
Reference ADEPEM : 005285
Bouton programmateur
Type: BoutonsArthur martin, Zanussi, Faure
Reference ADEPEM : 054450
Came de bouton programmateur
Type: BoutonsFaure, Zanussi, Electrolux
Reference ADEPEM : 059186
Charniere de hublot
Type: CharnieresZanussi, Faure, Arthur martin
Reference ADEPEM : 046826
Charniere de porte
Type: CharnieresCurtiss, Urania, Blue wind
Reference ADEPEM : 072426
Collier de soufflet inferieur
Type: Colliers et clipsFaure, Arthur martin, Curtiss
Reference ADEPEM : 036400
Collier plastique
Type: Colliers et clipsArthur martin, Electrolux, Zanussi
Reference ADEPEM : 017295
Corps bouton programmateur
Type: BoutonsArthur martin, Faure, Zanussi
Reference ADEPEM : 054451
Courroie 3l515
Type: CourroiesAriston, Bsk, Curtiss
Reference ADEPEM : 005386
Couvercle boitier tiroir lessive
Type: Capots et couverclesZanussi, Faure, Arthur martin
Reference ADEPEM : 099478
Couvercle filtre de vidange
Type: Capots et couverclesFaure, Urania, Zanussi
Reference ADEPEM : 145600
Durite cuve-filtre
Type: Tuyaux et duritesFaure, Arthur martin, Curtiss
Reference ADEPEM : 020526
Type: Tuyaux et duritesFaure, Zanussi, Arthur martin
Reference ADEPEM : 034989
Fixation manchette superieure
Type: Supports et fixationsArthur martin, Faure, Curtiss
Reference ADEPEM : 050393
Hublot en verre
Type: HublotsZanussi, Arthur martin, Faure
Reference ADEPEM : 017294
Joint distribution
Type: JointsArthur martin, Faure, Curtiss
Reference ADEPEM : 005551
Type: Plats et plateauxBluesky, Far, Galanz
Reference ADEPEM : 048190
Type: PompesCurtiss, Far, Selecline
Reference ADEPEM : 040576
Portes tambour par 2
Type: Cuves et tamboursFaure, Arthur martin, Electrolux
Reference ADEPEM : 018942
Poulie tambour
Type: Pignons et pouliesZanussi, Faure, Arthur martin
Reference ADEPEM : 038452
Pressostat 100/60
Type: PressostatsUrania
Reference ADEPEM : 065333
Programmateur
Type: Minuteurs et programmateursFaure, Zanussi, Electrolux
Reference ADEPEM : 055015
Rail
Reference ADEPEM : 078442
Ressort
Type: Amortisseurs et ressortsArthur martin, Faure, Curtiss
Reference ADEPEM : 005553
Ressort de cuve
Type: Amortisseurs et ressortsCurtiss, Faure, Urania
Reference ADEPEM : 056175
Thermoplongeur 1950w
Type: ResistancesZanussi, Arthur martin, Faure
Reference ADEPEM : 036449
Croisillon de tambour
Type: Roulements et paliersZanussi, Arthur martin, Faure
Reference ADEPEM : 047522
Type: JointsOceanic, Proline, Thomson
Reference ADEPEM : 156644
Durite cuve-filtre
Reference ADEPEM : 042514
Joint 31x52/63x12
Type: JointsFaure, Curtiss, Urania
Reference ADEPEM : 008985
Type: PompesUrania
Reference ADEPEM : 205793
Poulie tambour
Type: Pignons et pouliesFaure, Zanussi, Electrolux
Reference ADEPEM : 040704
Soufflet de hublot 481146667616
Type: JointsFaure, Curtiss, Arthur martin
Reference ADEPEM : 008986
Thermostat 60°nc/218 481928248047
Type: ThermostatsWhirlpool, Bosch, Laden
Reference ADEPEM : 014107
Pompe vidange px-2-35 0022150033660401
Reference ADEPEM : 080540
Tuyau d'evacuation
Type: Tuyaux et duritesFar, Curtiss, Franger
Reference ADEPEM : 043853
Pompe de vidange 481936018189
Type: PompesWhirlpool, Ignis, Laden
Reference ADEPEM : 014247
Programmateur 14478.01
Type: Minuteurs et programmateursDomeos, Far, Siltal
Reference ADEPEM : 147449
Tuyau evacuation seche-linge
Type: Tuyaux et duritesFar, Curtiss, Laden
Reference ADEPEM : 015726
